The following connections are required during installation and upgrades so that Universal Compute Platform can download the appropriate packages.
| Domain Name | IP Adresses | Protocol | Port |
| docker.io | Dynamic IP range | HTTPS | 443 |
| gcr.io | Dynamic IP range | HTTPS | 443 |
Internet connectivity is required in these situations:
Once the stand-alone cluster is created, internet connectivity is not required while installing, upgrading, or running application engines that run on the appliance (unless the specific application engine requires it, or unless you onboarded to the cloud).
If the appliance is to be deployed as an air gap use case, the initial configuration of the host needs to take place in a staging location where internet services are available (for example, DNS, NTP and Docker access). Once the node is initialized to support the target application, the appliance can be moved to its target location.The following connections are required if you connect to ExtremeCloud IQ.
| Domain Name | IP Addresses | Protocol | Port | Description |
| hac.extremecloudiq.com | 34.253.190.192 ~ 34.253.190.255 | HTTPS | 443 | Onboarding to ExtremeCloud IQ |
| <rdc>-inlets.extremecloudiq.com | Dynamic IP range | TCP | 8090 | Ongoing connection to ExtremeCloud IQ |
